Edit template to set default spaker volume
BW~Merlin
Forum User
I have made a custom template for our Yealink T19P E2 that has the DND button removed and this is working. I would now like to set the default paging volume and ring volume on these phones to be at maximum volume. I am having a little trouble seeing in the template where I can set these. Is it possible to set the volume settings in the template and if so where do I set it?
I don't believe it's possible to pre-configure the speaker volume after reviewing the template. I believe the default Yealink template has that functionality but 3CX's template does not. Either way it's not recommended as custom templates are not supported by 3CX
But OP is already using a custom template.. so that's not even a concern at this point.
While I know it isn't recommended to us a custom template I thought it was also recommended to not edit the existing templates. Either way if the default template has the ability to set the speaker volume and to remove the DND button then I do not mind editing that template.
@BW~Merlin
Please add next two parameters to your template:
force.voice.ring_vol=15 to set the ring tone to max. volume and
multicast.listen_address.X.volume=15 to set the volume of the speaker when receiving a multicast paging call.
Ravex comms
