Export CSV Reports Limitation
nicolasGa
Titanium Partner
I would like to export in CSV Call Log from 18 november 2023 to 18 november 2024 (so 1 year).
But i only have a 2.4Mo file, with 20.000 lines, that doesnt reach 18th nov 2023.
Is this an expected/normal behavior? Is there a way to avoid this?
Thx,
Thx,
Did you find any solution to this? Looks like we only manage to export 20k to csv at a time
As another alternative that performs this function automatically on a scheduled basis (every 60 seconds for example), you may want to take a look at our 3CX Exporter tool.
With our tool all your history can be replicated in near real-time to a secondary server. This ensures that you have all the historical information needed to generate reports, while ensuring your 3CX is optimized for performance, AND it means your backups are way smaller too.
We include the new v20 U6 tables as well. In 3CX v20 U6 you can automatically replicate some of the data, but not all, and the minimum frequency is 1-hour. That does not really work for time sensitive or real-time wallboard.
I have highlighted some key features:
  • In the top-right you can see it is in the process of replicating the data in each of the selected tables
  • On the top-left you see the configurable replication frequency
  • In the center is the list of selected tables to replicate
With our tool:
  • You never accidently truncate data and lose history
  • You get the data in near real-time (or real-time in the case of CDR file data)
  • You get ALL the 3CX data
  • You can eliminate the overhead of running custom reports on your 3CX server
  • You keep your 3CX server lean and optimized for performance
  • You reduce the size of your backups and increase the speed of restores
  • You do not have to do anything -- it is all fully automated
ARKC
