Failover on Hosted
Kitt
I am trying to set up failover between a 3CX Hosted instance (active instance) and a separate cloud-hosted instance (failover/backup instance). It has an Enterprise license. The 3CX Hosted instance is already configured and running, and backups to an off-site location have been started. The "Failover" button in the "Backup & Restore" section is still greyed out and cannot be selected.
I read the hosted PBX FAQ (https://www.3cx.com/blog/docs/hosted-pbx-faq/), which states, "No scriptable IVRs or HA Configuration." I read that to mean that I can't script IVRs, and I can't add HA/failover scripts but not that failover wouldn't work. I read the Failover docs (https://www.3cx.com/docs/failover/) and nothing there says it shouldn't work in the 3CX Hosted environment.
Is failover of a 3CX Hosted instance really not supported, or am I missing something in the configuration?
I appreciate any insight or troubleshooting steps.
I don't know what you could do to 'break' that button so I'm gonna say that it's not supported although the wording is poor if that description means no HA.
Hi Kitt,
Failover is not supported on Hosted By 3CX.
Linked guide has been updated to make it more clear.
Reactions: Kitt
fransisco
