- Joined
- Jun 17, 2019
- Messages
- 26
- Reaction score
- 0
We ran the latest udpates to 3CX Version 16.0.676 over the weekend. Prior to running this update everything was working fine. Now this morning we noticed The "Destination if No Answer" "Voicemail Box for Extension" settings have a stopped working. instead of forwarding calls that are not answered to the selected mailbox the calls are being terminated \ ended by 3CX
here is an example from the activity log. The call comes in, goes to a ring group with priority hunt, cycles through ringing the extensions correctly. Then disconnects the caller instead of transferring to voicemail.
10/21/2019 10:54:41 AM - Leg L:82.1[Line:10000<<xxxxxx6798] is terminated: Cause: CANCEL from xxx.75.215.146:5060
10/21/2019 10:54:26 AM - [CM503025]: Call(C:82): Calling T:HuntGrp:805@[Dev:sip:[email protected]:51273;rinstance=0-a9cfe9fcf83e4487ad6329303e0a4236;ob] for L:82.1[Line:10000<<xxxxxx6798]
10/21/2019 10:54:11 AM - [CM503025]: Call(C:82): Calling T:HuntGrp:805@[Dev:sip:[email protected]:53003;rinstance=0-3cbd4612ad524fb496b12aa6dbf0aa12;ob] for L:82.1[Line:10000<<xxxxxx6798]
10/21/2019 10:54:11 AM - [Flow] Call(C:82): has built target endpoint: HuntGrp:805 for call from L:82.1[Line:10000<<xxxxxx6798]
I haven't been able to figure out what is going on. I have tried using different mailboxes with the same results. Internal seem to forward correctly to the mailboxes. its just external calls that are being terminated.
Thoughts?
Thoughts?
