Solved How to playback recorded audio?
KarlynG
New User
I'm trying to do a very simple test where I playback the audio recorded by the user. I'm using the record audio component and afterwards a Prompt Playback component referencing the Recorded Audio Prompt giving it the Audio ID Expression (RecordComponent.AudioId). I have configured an audio that plays after the audio is recorded which plays fine, however, the audio recorded is not playing back . Am I doing this wrong? How could I achieve this?
Weird, what you described is the way to do it. Do you see any error in the 3CXCallFlow.log?
Just tested this case here, and works as expected. You should enable verbose logs and check the 3CXCallFlow.log file.
I checked but turned out my problem was that I was only saving the name of the file without specifying any extension. I'm new to CFD and I thought the input "File name" would save the audio with a default format just by giving the name. After I changed "user_audio" to "user_audio.wav" is now working!
Reactions: edossantos
Thanks for the feedback!
arming
