Intercom to Yealink 46S from Polycom VVX400
MikeDak
Trial User
3CX 15.5.15502.6
I'm upgrading phones...but mostly Polycom still. I can Intercom Poly-to-Poly, but not Yealink-to-Poly.
Maybe just compatibility issue?
#Enable or disable the intercom feature; 0-Disabled, 1-Enabled (default);
features.intercom.allow = 1
#Enable or disable the phone to mute the Speaker when answering an intercom call; 0-Disabled (default), 1-Enabled;
features.intercom.mute = 0
#Enable or disable the phone to play the intercom warning tone; 0-Disabled, 1-Enabled (default);
features.intercom.tone = 1
#The following parameters only applicable to V80
features.call_invite_format =
features.transfer_type =
#The following parameter only applicable to V80
phone_setting.logon_wizard_forever_wait =
features.caller_name_type_on_dialing =
gui_input_method.delete =
features.off_hook_answer.enable =
#Enable or disable the phone to barge in an intercom call; 0-Disabled (default), 1-Enabled;
features.intercom.barge = 0
Using stock templates and firmware? What does can't mean? It rings instead of auto-answers? You get a busy signal? More info would be helpful.
Sorry for the delayed reply...I've tried stock, and custom. Polycom rings, but will not pick up.
JensVoss
