Solved Limit incoming and outgoing calls
jskinner97
Intermediate Cert.
I am new to 3CX. Please can someone tell me how to limit the amount of incoming calls to 2, so that I can allow 3 outbound calls at all times. The SIP capacity is set to 5. Would this be the Call Queue feature, and setting it to 2 will prevent any more inbound calls?
Yes providing you have no other DIDs on your trunk going elsewhere.
obviously you'll need 8SC to have 5 SCs.
Reactions: jskinner97
Hi @jskinner97
If you specifically wish to limit the people reaching your queue then yes. Any one else will reach the "destination if no answer" which will steal consume a call channel unless you "End call"
If you have other DIDs that don't go to a queue, those can still receive calls and use up capacity.
you can use 2 trunks from separate SIP providers one for incoming traffic one for outgoing, you can set each like you want and cherry on the cake you increase security public links using 2 providers.
Brilliant! Thanks guys :)
Guriqbal Singh
