Need to display company name in CTI/soft phone
elogic
I think is a good idea having the company name of the caller identity displayed on the CTI and soft phone
This is really helpful when used in conjunction with the caller ID resolve from company phonebook
Let user to choose which information display looking at the phonebook entries simply adding an option in the settings
thanks
Marco
Upvote 63
+1
It's in the database for each contact we have, it's really sad we can't just display the company name too, as it would help our employees a lot.
+1 (how is this not a feature yet? we might not go with 3CX because this is missing!)
+1 and probably + many more. They don't want to implement this, obviously! For 5 years no progress on it.
+1000
Should also show company name in the contacts without having to open the contact - name above company name:
FName LName
XYZ Company
Sounds like you guys just need to use CRM integration and call pop
Thats all very well if you have a supported CRM.
If you have a Web-based CRM and it has an API, you can build your own template for it. If there's no API, you can use the Database templates to query directly the tables.
SupportRock
