Solved Out of Office Hours for Ring Groups
Scott EIT
At the moment we have a global OoO setup which works well however, one of the departments has different office hours too the rest of the office.In short, is it possible to setup different OoO hours for separate ring groups?
How does one reach that department? If it is a separate trunk DID you can define its own working hours with "Set up Specific Office Hours for this trunk " and send the calls to your queue accordingly.
Unfortunately it's the same trunk as the rest of the business.
So how do you differentiate/reach your departments? If its via a digital receptionist, you can send each IVR choice to a dummy extension that has its own custom hours, and that will either send the caller to the queue or send them to the out of office hours destination and they can run independently from each other
We use a digital receptionist. How do you create custom hours on the extension?
Reactions: Scott EIT
Inbound rules also has it's own scheduling. If you can isolate that department by DID and use inbound rules you'd be set.
Glad to hear it was resolved
GP Concepts
