Solved Prevent external callers to dial extension when ringing IVR (Digital Receptionist)
LeoG
I was looking for a way to prevent external callers to dial extension when ringing IVR (Digital Receptionist) and I've seen many posts about using advanced parameters such as IVRDONOTCALL or IVR_DIRECT_DIALING_GRAMMAR with a regex.
Problem: hosted instances do not allow access to advanced parameters.
A solution was handed to me by the support. I tested and it works: configure your Digital Receptionist with "DTMF Input" instead of "Standard".
This allows the user to dial specific DTMF input but prevents the caller to call whatever extension on your system...
Wonderful, I can continue using the hosted version!
...Resolving...
circusduck
