Problems with install on Azure
Alex Hutton
I have just taken up the 1 year free install onto Azure. when i try to log into the management console website, it won't accept the password and keeps blacklisting my ip. I also can't logon to the VM via SSH using the account pbxexpress.
So, my question is: Can i do a complete reinstall somehow or is there a way to reset the passwords while i can't log in
I can log in to the client interface but not the management one.
Well if you did it on azure, that's your azure subscription yet? So you can absolutely reset the ssh password or delete it and start over.
Thanks for the reply. I'm looking for a way to reset the management web console password so I can manage the phone system.
So after one or two failed attempts (before getting blacklisted) 3CX should give you the option to email the password to the license holder email.
Did you enable IP based console restriction? Because if you did then a reset will not help.
batarong
