Solved QUEUE, IVR, Ring groups dissappeared after upgrade V18
jrgdnn12
what went wrong?
It was fine on V16 running on lightsail instance installed by PBX express. Then after the upgrade to V18 I cannot longer see my settings. The PBX voice continues to work as before the upgrade.
I have just updated my system running on a Raspberry Pi4 and have exactly the same
Make sure you are using the main administrator and that you cleared your browser cache.
same here, its resolved. Thank You
GP Concepts
