Solved Recording Option Not visible in WebClient
amannick
Gold Partner
Hi @amannick,
To be sure, when selecting Manager as the Role are you then checking the 'Can see group recordings (Available in Professional and Enterprise)' box? It is not selected by default.
If it is checked, where are you checking the recordings? Have you ensured that this extension is in the correct group?
Helo @VasilisV_3CX
I have checked the option can see group recordings.
But its still not showing recording under Manager's webclient
and Manager rights were given and all the option are checked.
Aman Nick | The Telephony Co.
www.thetelephony.co
Hi @amannick,
Hi @amannick,
Just to confirm, you have enabled Show Call Recordings under the Extension >> Phone Provisioning >> 3CX App?
So the issue is that you can see the recordings tab in the Web Client but you're unable to see any of the group recordings therein?
Reactions: JanBa
Hi! Glad to hear that it's been resolved! Feel free to open a new thread if you need any further assistance!
Reactions: amannick
gmacinit
