route calls between two queues
lsh
I'm looking to route calls between two queues based on the status of an extension, exactly if that extension is in DND status, the call should be route to the second queue
What i currently have but that not working and i don't see why.
For more details
You're comparing strings, remove the quotes from GetExtensionStatus1.CurrentProfileName.
done, and still not working.
Condition 1
Condition 2
Extension 003 should become "003" (with quotes), otherwise it will be treated as a number, removing the leading zeros, and not finding the extension.
hey, that was the problem, it's working now, thank you.
So the field name extension need quotes oterwise the value is treated as a number...
Yes, this is only noticeable when your extensions start with 0, otherwise it would work as the number will be automatically converted to a string.
Reactions: lsh and Evolute IT
asandris
