Send recording without pressing key
albertozogno
I've just implemented a call flow app using the following procedure:
https://www.3cx.com/docs/cfd-emails-voice-app/#h.1my4nsjh5z8k
It's a very nice feature and it works fine but I have a question:
If during the recording I hang up the phone, the message is not saved and sent.
Is it possible to make it work without pressing any key?
To do that you have 2 options:
1) Instead of using separate components (Record and Email Sender), you can use the Record & Email component, which will handle the hang up for you automatically.
2) If you need to use separate components, you will need to do the email sending from the Disconnect Handler flow.
Graham Robertson
