Shared Parking notifications/unparking on a multitenant server
bradk
We have a client on a multitenant server that heavily uses their shared parks and find it easy to forget about parked calls, so they are requesting some kind of notification or automatic unparking after a set time. I understand that there is a system-wide setting to automatically unpark calls, but since they are on a shared server I would not want to turn that on for the other clients on the server.
Has anyone implemented a solution for some kind of timed unparking/park notification with call scripts? Could you share your method for doing so?
Thanks.
Not possible, even via call script. Maybe via the C# CallControl API.
@VoIPTools would know best.
It is certainly possible to transfer a call from the park location after X seconds using our API and/or send a reminder notification. But given that this is likely a very small customer, I question whether the cost of building a custom solution would be justifiable. We have a minimum project size of $1,500.00.
Hello bradk,
There is a 3CX CallScript "personalparking"
This seems to work on basis of Departments
You could setup a few of these ?
Paulo
Graham Robertson
