SPA 3102 Help!!!!
C51
hello have just purchased 2 linksys SPA3102's and cannot make either of them work with my 3cx server
can someone help me please
thanks
jordan
GOT IT!!!!!!
Results coming soon
That's mean your Line 1 registration is ok.
So, now let's test dialplan.
Can you please say which number (how much digits) you're calling and give your dialplan string. It is in the Line 1 tab in the bottom.
done
The ports on the spa need to be different 5060 and 5061 line 1 and pstn then you can check the 'Request-Line-URI' field. otherwise if you check the button you get a busy signal !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
3 days for 1 port UGGGGGGGHHHHH
Jordan, did you receive my email with screens? Didn't work?
got them thanks. it turns out the ports needed to be different on line 1 and the pstn.
Ouch! Sorry. I printed those before I made that change and never noticed. Was with the best of intentions, I apologize. Works now?
VOIPEric
