Solved Support Disable your SQL Database Integrations
Lanindigo
Hello, everybody.
My company is using a 3CX system running on the Web Chrome platform, I'm going to try CRM Intergrations in Setting but I don't see the "Server side" section so I can't choose "NONE" as a guide, Team can support me, thank you Team.
Reactions: N_G
There is no need to worry as for your license key there is no CRM available and this is why you do not see the Server Side CRM.
Let me ask, if so, should I wait for the updated patch today or tomorrow to be safe from this new vulnerability? Are there any additional steps I need to take now?
This affect only SQL integrations, you can check our blog post for what SQL integration is affected.
You can stay as you are if not planning using SQL integration.
Has this been patched or addressed in any way?
We use(d) SQL to journal call data for a project that was put on hold when this was announced.
-Mike
apbGroup
