TE110P - PCI card
HenriquePrevide
Dear.
I am a beginner with 3cx.
I am installing 3CX (15.5) for testing, however I need to connect E1 through PCI card. I´m using a TE110P E1 R2 Asterisk (Similar Digium).
I could not find where I set the trunks for E1.
Can anybody help me!
Thanks a lot.
I believe it has always been the case, that 3CX does not officially support any PCI card gateways. Whether you can get it to work (or someone else has, that can offer advice), is another matter.
https://www.3cx.com/voip-gateways/
Its sort of a grey area - beroNet provide PCI cards which are no different that the standard gateways - I have deployed them and the setup is no different than the stand alone gateway (other than a bridging setting on the local PC).
This is an un-supported PCI/Gateway device anyway - the first step I would think would be to setup an ISDN gateway in 3CX as a "generic" device and then configure the settings on the card manually from 3CX.
3CX can't talk to the card directly. Sangoma PCI cards (when they were supported) used to have a software component that would talk to the card and then present a local SIP server. 3CX would then talk to the localhost SIP server to use the T1/E1. The software was called Netboarder Express iirc. I don't believe Digium has such software equivalent.
jmarshall
