Understanding Holiday/Office Hours
Wilbo
I am in the process of setting a clients Holiday and Office hours back up. I've been doing some reading on the new V20 setup for doing this. I've tested it working properly but, I am having trouble finding documentation on what the "prompt" does in the Office Holidays setup. As I understand it the Holiday hours will redirect calls to the configured IVR (based on Call Handling settings) during the times at which these hours are set.
What does setting a prompt in the Office Holidays settings exactly do? Is this just playing prior to re-directing to the configured Holiday IVR?
Thank you!
So the "prompt" in that menu is only for the call processing scripts otherwise just uploading something there without a script is going to do nothing?
Thank you!
Correct. But you can select any prompt to play from within the Call handling, in the destinations section.
Reactions: Wilbo
Thank you!
For now. But that is changing in the next update from what I could read.
That's how I have it currently configured for Holidays in this particular instance, mostly just couldn't find documentation describing what that prompt location is for.
Where can I find information about this?
cdebbo
