Unsupported SIP Trunk Providers error on Dashboard
TPR3CX
Greetings,
Today I noticed the following error on my 3CX dashboard:
You are using Unsupported SIP trunk providers which may cause issues.
For a list of supported SIP Trunks visit this page.
My SIP Trunk Provider is FlowRoute, a preferred provider. Everything works great.
Why am I getting the error?
Did you use that provider from the list, or did you set it up as generic? If the latter, then it will still show the error. I think it should be a warning in a different colour as it is not an error in any case.
Just a thought but try checking the supported providers list for your country and see if they still exist:https://www.3cx.com/partners/sip-trunks/
I have known providers to fall off the list without prior warning so best to confirm.If not as above confirm you have used the in-built template with 3CX or Generic.
Flowroute is still supported. I use the Flowroute template and am not getting any warnings.
By any chance have you exported / imported your providers?
Long story short, you'll need to delete and re-add the trunk using the template.
Hello @TPR3CX
As mentioned, make sure that you are using the provided template to add your trunk to the PBX. If you used a generic template or imported your template then the management console will flag your trunk as unsupported.
mjwhyman
