Update 6 - Release Candidate: New Headset Functionality
N_G
Founder
Sneak preview! Update 6 has reached Release Candidate (RC) status, as 3CX Developers move to ‘Code-freeze’. With all QA test checks on Linux and Windows completed with thousands of customers worldwide, we’re now up and fully running in 3CX production. We’re confident it’s ready for you too! In a nutshell, this very important RC brings you...
Excited,
Will soon be pushing this to all clients
Reactions: N_G
Don't yet install RC version in prod envelopment waiting Release of U6
Hope everything will be OK with RC
This is great!
Where can I report translation errors or adjustments? I noticed a couple of missing French translations in the WebUI. Thanks
This is great!
Hi Connexium, Send me a P.M. and let me know
Hello to all,
Did you find a list of headphones that support WebHID?
Hello to all,
I can tell you Yealink should work, and Grandstream does not lol
  • Haha
Reactions: Connexium Partner
It seems that the following guide is no longer up to date.
https://www.3cx.com/docs/supported-sip-trunk-requirements/#h.9lv8vi548lbk
I notice now that there must be
XML:
<field name="HasWebhook" status="readonly">1</field>
to display a "inbound" SMS Webhook URL .
However, I cannot receive SMS messages in the PBX.
I can send but not receive.
Is there anything else that needs to be changed?
Ps.: My incoming/outgoing SMS tests work in 3CX v18.5
thx :)
XML:
thx :)
Update :
Ok ok,
I'm sorry, I'm sorry, it's my fault.
In my POST data, I can no longer send to 3CX ...
JSON:
"media_url": "",
"media_file_name": "",
"The JSON Keys" cannot contain empty values !
:p
My wife keeps telling me to follow the assembly guide when buying new furniture !
Must believe that his advice also applies to 3CX ...
"Guillaume, follow the instructions of 3CX and you'll be fine"
that said, for those interested, the Provider Template must now contain;
XML:
HasWebhook [ Yes or No ] , it leaves room for imagination. Who knows, it may leak as a clue that 3CX is already at the stage of providing RCS (Rich Communication Services) support. :cool:
Or, I'm completely wrong, maybe it just means.. "Enable WebHook" .. lol xD
Self-mockery (To make fun of oneself) :D :
I make myself scenarios, as if I could "discover" the secrets (new features) of future 3CX releases, as if 3CX was "hiding clues" to satisfy the curious like me lol xD What I don't know is that maybe the 3CX devs are looking at my post and suggesting to their leader....
"We should add/hide a fake phone template in the next release.
Make it look like 3CX is going to will launch a Desktop phone".
!!!! That would be terrible, as joke lol ! xD
  • Haha
Reactions: N_G and accentlogic
Update :
Ok ok,
JSON:
"media_url": "",
:p
XML:
Check out the update files in the logs... messaging provider is a new one and contains currently Facebook and WhatsApp. My guess is RCS might come there or Telegram.
FYI, new update removed the API key for SMS. No worries easy fix.
Finally getting some time to try update 6 RC and the new groups.
To check my understanding, in order to ensure the group timezone and holidays are applied to a call on an existing trunk (from an upgrade) with many inbound rules for DIDs:
  • From the management console (MC) > inbound rule > select the destination to be "send to call group" and pick the group representing your branch/dept.
  • Move to the web client/desktop app and go to admin > groups and 'call routing' link that takes you over to the office hours menu and from there route the call to your queue/ring groups?
  • The timezone / office hours applied to the user come from the 'main group membership' on the user record in the web client (can't see that field anywhere in the MC).
A few queries,
  1. Will you add multi-user bulk editing functionality to the webclient > admin > users section in the future? Or if multi-editing is to remain in the MC as an advanced feature can you please expose the 'main group membership' field to the extensions section?
    Looks like the main group membership drop down list is ordered by when the groups were added to the user, so it is a different order for different users. Means you have to click through each user one at a time to apply the correct main group?
    The CSV export from the web client only includes first/last name, email, mobile; no group membership. Likewise I couldn't see main group field in the MC extensions export CSV. So appears to be no bulk way to assign main groups membership?
  2. If using MC inbound rules to send calls to groups on existing DIDs, there are in office hours and out of office hours routes on the inbound rule. Is it basically a 1:1 mapping to the in/out office routing in the webclient group routing? eg: You send both the inbound rule in/out office hours to the same group. But I assume this means you could override (accidentally or on purpose) the out of office hours routing at the rule level to somewhere other than the group.
  3. If you add a new supported trunk from the webclient > admin > voice and chat section and 'limit it to a group' rather than 'system wide', I can't find a way to change that choice later other than deleting and re-adding the trunk to be system wide? Is that the case at the moment?
Cheers. Looking forward to handling multiple timezones / holidays in one system.
@MarkNAS - Thanks for summary - see feedback below
Well, you can also just assign the DID directly to the group from the webclient
Thats where you configure groups for times yes
Yes
  1. If using MC inbound rules to send calls to groups on existing DIDs, there are in office hours and out of office hours routes on the inbound rule. Is it basically a 1:1 mapping to the in/out office routing in the webclient group routing? eg: You send both the inbound rule in/out office hours to the same group. But I assume this means you could override (accidentally or on purpose) the out of office hours routing at the rule level to somewhere other than the group
You have to choose one or the other. Either send to group or keep old system wide hours
  1. If you add a new supported trunk from the webclient > admin > voice and chat section and 'limit it to a group' rather than 'system wide', I can't find a way to change that choice later other than deleting and re-adding the trunk to be system wide? Is that the case at the moment?
At the moment no
There was no option to start a SMS chat from the webclient, after a closer look all my trunks SMS API keys were missing and none of them were enabled.
Got it. I will PM you for some details
FWIW, I upgraded from 418 to U6 RC on a test install and didn't lose the SMS key or user settings.
Reactions: N_G and Evolute IT
admintest
