Update 8 Release Candidate
N_G
Founder
Feedback and fixes in preparation for final release.​
Following feedback after the recent Update 8 BETA, we’ve done more testing and followed through with a good number of fixes as a result. We’re moving confidently forward with the Release Candidate today. Read on for a summary of what\'s included as well as details on who ...
Hey,
Can there be a feature added in the webclient to check for updates? instead of restarting the application? Maybe at the system tray menu?
You can go to the Admin Console and see updates. Just a click away
Hey,
As an end user I doubt you'd care about updates.
As IT, you would be advising/doing the update.
Hey,
If you mean the desktop app actually, it will check every couple of hours and if it finds an upgrade it will notify the user, so no need to manually check for updates.
If the user clicks no when the upgrade is offered, then the app will install the upgrade when it gets relaunched.
Things about updating 3CX client applications.
Is it possible to add a function to check the status of the client after automatic downloading of updates ( Ready \ Busy \ in a call \ Do not disturb ) and in the case of the "Ready" status, automatically send a restart command to the client for finish updating. I think this check will automate the update of all clients.
Hello
it seems that the From (Display Name) is not taken in account in the Email Settings :
If using the 3CX SMTP it uses info from the License key. This field likely only applies for using custom smtp.
Thanks for the quick reply, wasn't aware of this limitation !
Hi.
I remember that with Update8 for local installed 3CX you need to use a Split-DNS.
Bye
Timm
Hey, you pushed GA update but there is no change log available yet
sherry reynolds
