Update Failing (SaltStack issue?)
ip25
Evening All,
We've got a few instances that won't update with the below logs, all running on Debian and deployed using the PBX Express tool. Trying to get the latest update rollup...
Hit:1 http://downloads-global.3cx.com/downloads/debian stretch-testing InRelease
Hit:2 http://security.debian.org/debian-security stretch/updates InRelease
Ign:3 http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch
InRelease
Err:4 http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch Release
404 Not Found [IP: 13.224.67.36 80]
Hit:5 http://downloads-global.3cx.com/downloads/debian stretch InRelease
Ign:6 http://cdn-aws.deb.debian.org/debian stretch InRelease
Hit:7 http://cdn-aws.deb.debian.org/debian stretch-updates InRelease
Hit:8 http://cdn-aws.deb.debian.org/debian stretch Release
Reading package lists...
E: The repository 'http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0
stretch Release' does no longer have a Release file.
Any thoughts?
Kind Regards,
Nathan
Hi Carlos,
Paste the entire output from the point where you enter the command, until the end and we can take a look
Yes, go ahead and let us know how it goes
I tried this method and now I cannot log on to the console. I get the message 'Server Error'. Too many issue with 3CX lately, not good. I am just about to migrate pbxes away from Elastix.
Oh just found out the server is broken and no pbx available. :(. Time for a restore!
@imagehq what method exactly, only ran this one command as root? Did you save the output to see if it ran successfully?
Bash:
wget -O - https://downloads.3cx.com/downloads/misc/debianpatches/9/16/0/5/20200619-os-update.sh | bash
The services will need to restart in some cases, so if you log in before that you will get a server error
SSH to your server as root run this command
Code:
nano /etc/apt/sources.list.d
or as a user run this command
Code:
sudo nano /etc/apt/sources.list.d
hi
I have a small appliance as a 3cx instance and can log in to the terminal via 3cx dashboard.
What do I type in the command?
I coppied and pasted the command suggested here but it says comand not found.
thanks
Hi @gluetome
The terminal from the dashboard is only for very basic stuff and does not allow you to run elevated commands, you need to connect to your machine via SSH.
Useful.
I found one of my VMs was not up to date and this was the cause. I took the route of deleting the line from the file per NSBR's post. Is that likely to cause issues in future? Any clues what caused this problem in the first place?
@wizards
Yes, take a look throughout the whole discussion and there is a description of what caused it.
Using the script we created should ensure that this never happens again in the future.
Roman Mazur
