- Joined
- Jul 1, 2016
- Messages
- 6,533
- Reaction score
- 2,558
I had screenshot the QR from his profile and sent it over to him - i left it open to stay alive for him, he was pretty quick to do it.Just curious, from where he's scanning the QR Code? I looked at the screenshot you provide, it doesn't looks like a WebClient, rather an eMail client
As i said, i left it open.Hello Alphabetic,
The way it works, is that the QR code does change all the time.
When you open the QR code screen (generate new), it does work, however when you send it by email and close the QR code on your webclient/admin than the QR-code is gone.
So yes, it's best that the pseron will scan the QR code from a pc/laptop directly.
Actually that is the only way it will work good and in the correct way.
Paulo
I dunno, i test it and it worked. never had a problem sending it out this way before tbf.Yes, I understand, and agree that it should have worked (have done this myself once before), so do you think this could have changed in release 8? or just some timeout on the scan that has got shorter?
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
