V20 Pro w/Patton SN4141 Gateway, phones constantly hang up when answering call and re-ring again.
PatM
Fresh new install with V20 4SC Pro license and have a situation where I have configured Inbound/Outbound call routing. If someone calls in, it hits Ring Group 80 for 2 extensions. You go pick up the call and it hangs it up, but then it rings the phones again, go to pick up and hangs up again and 3rd time will accept the call. Sometimes it works on the second attempt but never the first. Have removed the Patton gateway and rebuilt the config. Deleted the Ring Groups and rebuilt them and almost about to rebuild the whole system. Downgraded the phone firmware to test that and still an issue. Had it so inbound calls ring just 1 phone.
Phone rings Ext 10 --> Go to pick up and it then terminates the call and Rings another BLF Line key. Pick that one up and again and it terminates the call. I have deleted Ring Groups and made it so that the Patton only goes to a User extension and same thing. If I look at the Call Logs this is what comes back,
08/12/2026 5:15:42 PM000-05b 1617840Office (10)InboundAnswered-00:00:0100:00:070.00Inbound: MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000002) → Ended by Office (10)
08/12/2026 5:15:36 PM000-05a 1617840Office (10)InboundAnswered-00:00:0400:00:110.00Inbound: MOLETTIERI PAT (1617840 → Via trunk: Patton Gateway (000001) → Ended by Office (10)
08/12/2026 5:15:30 PM000-059 1617840Office (10)InboundAnswered-00:00:0200:00:180.00Inbound: [V]MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000000) → Ended by [V]MOLETTIERI PAT (1617840)
08/12/2026 5:13:38 PM000-058 1617840Office (10)InboundAnswered-00:00:0400:00:020.00Inbound: MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000002) → Ended by Office (10)
08/12/2026 5:13:32 PM000-057 1617840Office (10)InboundAnswered-00:00:0300:00:120.00Inbound: MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000001) → Ended by Office (10)
08/12/2026 5:13:26 PM000-056 1617840Office (10)InboundAnswered-00:00:0300:00:030.00Inbound: [V]MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000000) → Ended by Office (10)
08/12/2026 5:12:38 PM000-055 Office (10)16178401671OutboundAnswered-00:00:0400:00:080.14Dialed: (1617840) → Via rule: 11 Digit Outbound rule for Patton Gateway (1617840) → Via trunk: Patton Gateway (1617840) → Ended by Office (10)
08/12/2026 5:11:09 PM000-054 1617840Voice AgentInboundAnswered-00:00:0000:00:070.00Inbound: [V]MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000000) → Number not found
08/12/2026 5:10:48 PM000-053 1617840Voice AgentInboundAnswered-00:00:0000:00:070.00Inbound: [V]MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000000) → Number not found
08/12/2026 5:02:03 PM000-052 1617840Office (10)InboundAnswered-00:00:0400:00:020.00Inbound: [V]MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000000) → Ended by Office (10)
08/12/2026 4:54:38 PM000-051 1617840Ring FOH (80)InboundUnanswered-00:00:0400:00:000.00Inbound: MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000001) → Ended by MOLETTIERI PAT (1617840)
08/12/2026 4:54:32 PM000-050 1617840Office (10)InboundAnswered-00:00:0200:00:030.00Ended by Office (10)
08/12/2026 4:54:32 PM000-050 1617840Ring FOH (80)InboundRedirected-00:00:0300:00:000.00Inbound: [V]MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000000) → Ring FOH (80) was replaced by Office (10)
08/12/2026 4:52:53 PM000-04f 1617840Ring All (81)InboundUnanswered-00:00:0400:00:000.00Ended by MOLETTIERI PAT (1617840)
08/12/2026 4:52:52 PM000-04f 1617840Ring FOH (80)InboundUnanswered-00:00:0000:00:000.00Inbound: MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000001) → Ring FOH (80) → No destination available was replaced by Ring All (81)
08/12/2026 4:52:46 PM000-04e 1617840Office (10)InboundAnswered-00:00:0200:00:040.00Ended by Office (10)
08/12/2026 4:52:46 PM000-04e 1617840Ring FOH (80)InboundRedirected-00:00:0200:00:000.00Inbound: [V]MOLETTIERI PAT (1617840 → Via trunk: Patton Gateway (000000) → Ring FOH (80) was replaced by Office (10)
08/12/2026 4:43:30 PM000-04d 1617840Ring All (81)InboundUnanswered-00:00:0400:00:000.00Ended by MOLETTIERI PAT (1617840)
08/12/2026 4:43:30 PM000-04d 1617840Ring FOH (80)InboundUnanswered-00:00:0000:00:000.00Inbound: MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000002) → Ring FOH (80) → No destination available was replaced by Ring All (81)
08/12/2026 4:43:24 PM000-04c 1617840Office (10)InboundAnswered-00:00:0400:00:020.00Ended by Office (10)
08/12/2026 4:43:24 PM000-04c 1617840Ring FOH (80)InboundRedirected-00:00:0400:00:000.00Inbound: MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000001) → Ring FOH (80) was replaced by Office (10)
08/12/2026 4:43:18 PM000-04b 1617840Ring FOH (80)InboundUnanswered-00:00:0400:00:000.00Inbound: [V]MOLETTIERI PAT (1617840) → Via trunk: Patton Gateway (000000) → Ended by [V]MOLETTIERI PAT (1617840)
@PatM try to eliminate some factors here.
Setup the Ring Group with the 2 extensions.
Then from another extension call this Ring Group directly and answer the call from 1 of the 2 extensions.
Does the issue still persist ?
If not, this excludes the PBX from this case and you will have to check the logs
on the Patton device to identify the source of the issue.
Thank you @NikosT_3CX for the suggestion. Will attempt that when I return later this morning. Did some other testing after posting last night. Call the 3 phone #'s coming into the building my results were as follows.
Call in on 8024 main published #, whether it is using a Call Group or ring directly to just 1 extension, phones act up and are not working properly.
Call in on rollover # 8025 which is not published, call comes in and you can pick up as you would normally and no issues.
Call in on rollover # 8026 also not published and call performs as it should whether it is routed to a call group or a single extension.
Go to cal in again on main published # 8024 and phone rings, pick up and it terminates the call and re-rings again even though it shows you have already answered the call.
Have a call into the telecoms provider to see what may be going in on their side after discovering that last night. Also reached out to Patton to see what they have to say about it.
Reactions: NikosT_3CX
If you have access, check the 3CX Activity Log in Verbose mode. It may provide additional information about what is going on.
So was able to try and call RG80 from another phone and call pickup worked as it should, so definitely excludes 3CX from the mix on being the issue. Sent Debug log files to Patton as they had replied back. Will wait to see what they say, but also heard back from the telecoms company and their engineer may have found something on their end. Supposedly it all started when they had to send some custom firmware to get an older modem working to provide phone and internet. Hopefully this will be resolved by end of day, but not holding my breath on that as we are going on day 4 with issues.
Did check the activity log but not in verbose. Will look at it when I return again and see what I can find, if not activate verbose and call into the site.
Carlos - EC Mates
