What VOIP provider are you using - poll
N_G
Founder
What VOIP provider are you using?
Let us know the most popular providers out there. Let us know which ones you feel need to be supported as well... And let us know which providers are working just fine so we can add them to the supported list!
Thanks for your cooperation.
Re: cellip
henlon said:
Cellip AB in sweden own's mysercretary.net
I have tried several times to get 3cx work together with cellip.
The problem is to answer incomming calls. 3cx can't receive calls.
The provider works fine on stanalone sip phones
CellIP (mysecretary.net) works just fine for me both when it comes to incoming/outgoing calls. Is your 3CX behind a firewall? If so, make sure port forwarding (port 5060) is enabled on the firewall and that it forwards the traffic to your local ip.
http://www.iristel.ca
Does NOT work because they require different SIP ID and AUTH IDs.
freephonie.org is working for French users using the ADSL provider named "Free" .
( for outbound calls, I didn't try for inbound calls)
OpenIP.fr
http://www.openip.fr/ is working fine for French users.
Ask for Trunk SIP offer.
Regards
mytel
Succesfully using Mytel in Australia
http://www.mytel.net.au
using a office pbx connect plan with 4 calls at a time no problem
very good quality non a 512/512k ADSL Plan
For incomeing iam useing the voip numbers that my ISP (XS4ALL.nl) gave me, and for the out going calls to landlines iam using voipbuster.
Still looking for a real cheap voip to mobilephone out going voip provider.
:wink:
Gerard
I use Voiceworks (http://www.voiceworks.nl) from holland
Works as a charm without the supports reinvite checked.
VoIP Provider
I use vBuzzer (http://www.vbuzzer.com), VoipBusterPro, Skype (via software SIP adapter) and VoiceNetwork for DIDs. Skype was "interesting" but the others were straight forward. Would be nice if vBuzzer could be added to the pre-configured list. I also use Vonage but via their adapter and forwarded to vBuzzer for now.
VOIP in Brazil
I
voipproviders
Hi I am using:
4x Budgetphone (NL)
2x Voipbuster
1x Sipgate (DE)
1x Telfree (RSA)
Apart from some errors most of it is working fine and smoothly
I'm using
VoiceStick - http://www.voicestick.com/ - Free landline number in USA (very useful for international affiars)
Voiptalk - http://www.voiptalk.com - Free landline number UK
OrbTalk - http://www.orbtalk.com - Free Geo Landline Number UK
Sipgate are good for personal calls, but there DTMF/Touch tone handling isnt advanced enough for PBX/Menu systems as a hole.
VOIP in Brazil 2
Following up my other post the Tmais
Sipgate and Internetcalls...
Both work well.
The only problem with Internetcalls (http://www.internetcalls.com) is that they dont yet provide UK sip-in numbers. But they do allow connecting calls via text message, web, etc.. which is usefull. Also good for a backup failover service.
Sipgate - 90% pleased. No moans, yet.
DIGISIP and Phonzo
I use Phonzo and Digisip.
But the last one does note work at the moment because of the auth id differ from the phone nr.
Irish VOIP Blueface
I have build v3.0.1928 working fine with Irish VOIP provider Blueface (http://www.blueface.ie)
For some reason build v3.0.2295 wouldn't register the line, but I'll try upgrading to the latest build n a test server.
I am using
Voicestikc and Teliax without any problem. Both are great for international calling.
Canadian VOIP providers
I got both Vbuzzer (http://www.vbuzzer.com) and Les.net to work after a little bit of testing
thanks parker
VSP
I'm using MyNetFone (http://www.mynetfone.com.au) for 16 SIP lines.
I have packet 8
I have packet 8.net which is again a voip provider what type of information do i need to get before i procced with making changes to my 3cx software.
Engin in Australia http://www.engin.com.au
Rhameez
