What VOIP provider are you using - poll
N_G
Founder
What VOIP provider are you using?
Let us know the most popular providers out there. Let us know which ones you feel need to be supported as well... And let us know which providers are working just fine so we can add them to the supported list!
Thanks for your cooperation.
In the UK we are using voiptalk.org
Using BrainTel (not working)
I am using http://braintel.net.pk/
And it is not working. I need help to configuring BrainTel with 3CX. It successfully registers, but i can not make out going calls. It failed with 603 Declined.
The provider is using Asterisk PBX at their end and here is a working configuration with asterisk.
Outbound Caller ID: 210XXXX
Trunk Name: Brain
PEER Details:
username=210XXXX
type=peer
secret=YYYY
qualify=yes
progressinband=yes
port=8891
nat=yes
insecure=very
host=chat.brain.net.pk
fromuser=210XXXX
fromdomain=chat.brain.net.pk:8891
dtmfmode=rfc2833
disallow=all
context=from-trunk
canreinvite=no
authname=210XXXX
auth=md5
allow=g729
Based upon above I made the following changes to Gateway / Provider Outbound Parameters section and defined custom values:
To : Host Part = chat.brain.net.pk
If I am missing anything?
Here is the invite packet it is sending:
SEND: INVITE sip:[email protected]:8891 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d87543-d56833136165922f-1--d87543-;rport
Max-Forwards: 70
Contact: <sip:[email protected]:55287>
To: <sip:[email protected]:8891>
From: "100"<sip:[email protected]:8891>;tag=7b535454
Call-ID: NGY4OTcyMmZhZWI4MGExOWE0MDVlMTBkNmIwN2Y2MTY.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
Content-Type: application/sdp
User-Agent: 3CXPhoneSystem 5.0.3790.0
Content-Length: 247
v=0
o=3cxPS 18069061632 391496335361 IN IP4 24.16.98.7
s=3cxPS Audio call
c=IN IP4 24.16.98.7
t=0 0
m=audio 9000 RTP/AVP 0 8 101
c=IN IP4 24.16.98.7
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
I suspect that the issue is with To and From fileds where it is also including 8891 as the port, which might not be required.
I am using vonage and have been happy with it for the most part.
We use Binary Telecom (http://www.binarytelecom.com). Works well and easy to work with.
markh
We use
BudgetPhone
SipDiscount
VoipBusterPro
All without problems.
Re:
mbs said:
i have sucessfully used http://www.voipcheap.co.uk and http://www.voipcheap.com.
fwd ( http://www.fwdpulver.com) also works but i am not able to use * in the dialling string to call peers
thanks
mbs
wich are de si servers from this provider???
sorry i have them:
SIP port : 5060
Registrar : sip.VoipCheap.com
Proxy server : sip.VoipCheap.com
Outbound proxy server : leave empty
Account name : your VoipCheap username
Password : your VoipCheap password
Display name/number : your VoipCheap username or voipnumber
Stunserver (option) : stun.VoipCheap.com
We tested with ICall -- http://www.iburst.co.za in South Africa and it works with the "Generic Voip Provider" template
I am using SIPGate with no real problems
So far I like Broadvox. Very professional company.
Dear xxx,
Thank you for choosing BroadvoxGO! SIP Trunking Service. My name is Mike Dontenville and I’ve been assigned as your Project Manager for the provisioning and delivery of your BroadvoxGo SIP Trunk. I can be reached M-F from 9 a.m. to 6 p.m. EST at (216) 373-4644, or you may Email me at [email protected]. Additionally you can always feel free to call into our Customer Service Department at (800) 340-4583, Option 3, and our Customer Service hours are M-F from 9 a.m. to 9 p.m. EST.
This initial communication is to inform you that your service is being processed and to provide you with access to our on-line support system via portal login from our web site http://www.broadvox.net. When you access your portal the service ticket that you will want to reference is 293965. This ticket will remain open throughout the provisioning and turn-up process. Also, as a part of the turn-up process you will receive and Email from [email protected] which you need to simply reply to so that we may confirm you will receive Emails to this address. This address is where all invoices for service will be Emailed. Please see to it that associated Emails are accordingly routed to your accounts payable department.
Sipdiscount.com ? Help !!!! Settings ?
Can someone tell me what the settings are for sipdiscount.com ? It works with my ata box. But with the same settings no luck with 3CX. Did connect
an other voip provider, and it did work. So its not my router or firewall... Who can help me :roll: :cry:
Re: Sipdiscount.com ? Help !!!! Settings ?
i suppose that you are asking about this settings:
SIP port : 5060
Registrar : sip.sipdiscount.com
Proxy server : sip.sipdiscount.com
Account name : your SipDiscount username
Password : your SipDiscount password
Display name/number : your sipusername or sipnumber
Stunserver (option) : stun.sipdiscount.com
In the Manual at page 38
4. Enter the Voip line number that has been assigned to !????
I only have a username and password. If i use the username in this field,
I get an error Identification is invalid ? If i just put a number random no
error but de line goes not up ? Anny clu ? With other VOIP service i have a number and then it seems to work.
But Sipdiscount has no numbers only username and password ??? :roll: :roll:
Do i need to install the new version ??
Installed Version: 5.0.3752.0
Available Version: 5.0.3790.0
Your version is out of date
if you have only a sip account you may use an random number. Ex: i use for a sip account without VoIP in the next one: 010101010101. en it's working.
Just dont work :cry:
ClientRegs::Register :[CM504003]: Sent registration request for 10000@sipdiscount
ClientRegs::onFailure :[CM504007]: Next attempt to register 10000@sipdiscount is scheduled in 1 minute
ClientRegs::onFailure :[CM504005]: Registration failed for: 10000@sipdiscount
I'm currently using :-
* VoIPtalk (uk)
* The Tech Guy (http://www.the-tech-guy.co.uk)
...it has some really good rates, only downside is that you have to call up to setup an account at the moment, but im told it will all be online soon :)
voipbuster.com (now and then having problems getting registred)
callvoip.nl
voipgate.com
voipcheap (for testing)
voipgate.com (for testing)
Question, why is the popular voipbuster.com not in the standard list of 3cx ?
it is maybe an idea also a SIP trunking provider pool to do??
WAFI
