What VOIP provider are you using - poll
N_G
Founder
What VOIP provider are you using?
Let us know the most popular providers out there. Let us know which ones you feel need to be supported as well... And let us know which providers are working just fine so we can add them to the supported list!
Thanks for your cooperation.
yes, i also think its a good idea
Voipbuster (behind ISA2004) Without any problems
Sipdiscount (behind ISA2004) Without any problems
Voipq, callvoip.nl (Breezze,uunet) cannot register.
Voipq and callvoip.nl can register with a grandstream 2000 telephone behind ISA2004 without audio, so i'm looking for a solution/settings.
Remy
Hi!
I use http://www.vyke.com -> great to call out, very low prices... but cant recive calls...
And http://www.televoip.no -> get a telephonenumber here, use this to recive calls...
No problems with they... great support...
lars
is this site also in English??? http://www.televoip.no.
the another one vyke like me very intersting... also the soft phone voor mobile. do you have some experince with it???
Hi,,,
http://www.televoip.no is only in Norwegian...
http://www.vyke.com --> I use it on the mobile to send sms here in norwegian, it is cheap instead of normaly sms (the trafic are over GPRS). For call to another country I use it, but sometimes the line is hanging...
Lars
Teliax - so far, no problems on 3CX
Broadvoice - I have had nothing but issues with them and 3CX.
IP Communications (http://www.ipcomms.net) - Works awesome for hosting US boxes an overseas number. For Example; a UK 020 number they have a dedicated pipe from Level 3 so don't have to worry about lag (I am using this in a live call center). I have not tested IP Comms on a 3CX Platform, only Fonality's PBXtra (Asterisk).
I use WeePee Voip. Works fine. Sometimes troubles with long-distance international calling.. but that´s something I take with it... Overall I am really happy with it.
Two lines registered, no trouble at all.
Daniel
We try to use frephonie.net (From french free ADSL Provider)
Work with version 3 of 3cx but not with version 5 (No sound)
I can help you debug this issue if you wan't.
I've been using Internetcalls.com (another Betamax co.) for a couple of years now. Just set up a 3CX free edition server and calls are fine with them.
I had to make up a number for the external number field though as the username for internetcalls is alphanumberic.
Rob
that number is not so important. i use 1010101010 and it's going fine
I am using Voipstunt. A template for Voipstunt would very welcome. Since recently I loose the connection with Voiostunt after 25 seconds. Maybe my settings are wrong.
you need to use this settings:
General
SIP port : 5060
Registrar : sip.voipstunt.com
Proxy server : sip.voipstunt.com
Outbound proxy server : leave empty
Account name : your VoipStunt username
Password : your VoipStunt password
Display name/number : your VoipStunt username or voipnumber
Stunserver (option) : stun.voipstunt.com
and your firewall must bu all right
Mondotalk, Voiptalk both work great.
Use a general template- and input your details as per normal - very easy setup
We are based in Holland, we are using Solcon as our provider for our sip channels. the only thing is solcon normaly expects an voip server / client to indentify itself as [email protected] but 3cx indentify's itself as [email protected], the solution is found on this forum, ask Solcon to change the usernames into the telephone numbers (an dutch telephone number like 0320 123456 would be 32320123456 as username) then everything works great.
Just wanted to update:
I've been sucessfully using InPhonex, SipGate (UK), Ippi (FR), FreeDigits and FWD, with paid accounts on the first three. All of them have been very easy to setup and very reliable so far.
Halea
Swedish provider Teleman (http://www.teleman.se). Worked out of the box with "Generic VoIP Provider" settings.
I'm currently using:
IdeaSIP (http://www.ideasip.com)
Great prices to Italy mobile, friendly and responsive customer service.
Worked well with 3CX generic provider settings. Highly recommended!
Alex
In Greece i use I-call.gr mainly. I use also eVoice of HOL.gr. The first is better but the second gives a free dial in number with every subscription.
Can you actually use Vonage with a PBX system?
If so i guess you have to use vonage to set up extensions and stuff?
Am i right?
WAFI
