When calling out doesn't show a caller id
ecotech
SOHO User
When we call out it does not show a caller id or the phone number how can I fix this?
Are you using a support provider? I'm guessing not?
You'll need to run a wireshark trace on a call and see what's been sent in the invite.
I have it hosted in Azure
Who is the SIP trunk with?
You'd need to look at the caller ID control under the SIP trunk and see whats being presented.
Unless you have been tinkering with trunk properties, 3CX is sending the caller ID information. Have Flowroute perform a wireshark to see what you are sending. My guess is this is a problem at Flowroute rather than 3CX.
EMMEPICASA
