Solved Windows Client Issues Locally
AustinRM95
Doing a new install for a client, where many of the users are using the Windows softphone. Intermittently, if a user calls another user internally, the user on the receiving end answers.. however the user who initiated the call still hears ringing. It ONLY appears to occur when calling from one Windows softphone to another. Calling from a deskphone to the softphone works fine, as does the Android/iOS app.
Hello @AustinRM95
Try to enable the option "PBX delivers Audio" under the extension settings / Options / Troubleshooting and see if that helps with the issue.
Hello @AustinRM95
Thanks. That seemed to solve this issue.
neshima
