Yealink SIP-W60B disable call waiting
bleepingmachines
I have a Yealink SIP-W60B cordless phone added as a DECT phone. I need to disable call waiting but I do not see any options. How can I modify the settings?
Log into the base, goto "Features" > "General Information" and set "Call Waiting" to Disabled.
That's all.
Won't that get reset if the device pulls a new provision (i thought they reprovision after firmware updates)?
Edit the next parameter in the template
Code:
#Enable or disable the call waiting feature; 0-Disabled, 1-Enabled (default);
call_waiting.enable = 0
Where do you edit the template?
With a DECT phone, where do you apply this custom template?
