Yealink T-58 & Webclient
Derek P
Forum User
Hi There,
I know this is probably a fringe problem, but I was curious if anyone else had experienced something similar, or knows of a work around.
We performed the recent update to the newest version of 16, and it changed some of the look and features of the web client. This is great for newer hardware and browsers, but for the older browsers (ie internet explorer, and the one built into the Yealink T-58) will no longer load the webclient page. It just sits on the splash screen and never loads.
The reason we are trying to get this to work is that my boss uses the phone's web browser to access the listen feature inside the webclient. The t58 is using the latest firmware supported by 3cx.
If anyone has any input, it would be much appreciated.
Thanks!
Hi Derek,
The browser in this device is not supported, officially only Chrome is supported.
hughesdouglas
