Solved Yealink W60B Provisioning
Dennis Pillow
I can only imagine that I am missing something in the provisioning task of the W60B. My question is, "Is there any simple guide or file to show me the proper way to configure a W60B for provisioning on the 3CX Cloud Service"?
Hi Dennis,
A couple of points:
1. This is beginning to sound like a classic firewall problem, with the ports closing after a while of inactivity. You should really check whether you have properly forwarded the ports of the W60B on the firewall/router/modem that sits in front of it. It's kind of an important requirement for STUN devices with regards to reliability and should be your first go-to.
2. The latest 3CX supported firmware is 77.83.0.20 - Ensure please that it is running this version. You can get it from here if needed. You must click "Software" on their page to see it.
I just downloaded it and discovered that the firmware I have installed is 77.83.0.85. I am going to install the firmware I just downloaded and see what happens. I have the firewall checked and it is open to the phone. I will post the results here.
THANK YOU VERY MUCH!
Reactions: JohnS_3CX
Please factory reset the device because the settings of .85 may conflict with .20
Then after the firmware is installed, reprovision your devices as per our guide.
I have done that and it provisioned so quick it was scary. It has held and I was able to assign the W60b to the ring group and all is well so far. I will post any problem if it should arise. Again, Thank You.
Glad to hear Dennis
Glad to hear Dennis
Just a thought....I had no idea that a specific 3CX firmware was available for the W60B. I am just glad that you took the time to point me to the proper solution.
Yep, it's in our guide and it links you to Yealink so you can download the firmware from there (specific 3CX firmware section tested by Yealink to be compatible with our system)
footandankle.my3fcx.us
