We have some news for our Dutch customers and partners, we've added a new Dutch VoIP Provider to 3CX v15.5, Update 2. This means that you now have even more choice of SIP Trunks to use with 3CX. The new VoIP Provider which has been added is KeenSystems.
KeenSystems is a telecom operator which operates in the Netherlands and has been providing telephony services since 2004. With the use of high-quality equipment KeenSystems offers customers automation, independence, flexibility and complete control over their products and services.
Configuring KeenSystems with 3CX is ever so easy with our pre-configured template. All you need to do is login to the management console navigate to the SIP Trunks node, select Netherlands and KeenSystems and fill in the required fields. You'll be up and running in no time. Take a look at our step-by-step guide for more information on setting up KeenSystems with 3CX v15.5
Note that to use KeenSystems SIP trunk you must be running 3CX V15.5 Update 2 or above. We recommend that you always run the latest version of 3CX in order to ensure ongoing compatibility.
