Solved 3CX full backup - failed
regomotiv
Normal backups complete without any issues.
Trying to take a full backup before upgrading to v16 (Windows 10), I get the following error.
Any ideas?
3CX Phone System tried to backup but failed due to the following reason(s):
System.IO.IOException: The request could not be performed because of an I/O device error.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.ReadCore(Byte[] buffer, Int32 offset, Int32 count)
at System.IO.FileStream.Read(Byte[] array, Int32 offset, Int32 count)
at System.IO.Stream.InternalCopyTo(Stream destination, Int32 bufferSize)
at _3cxNetBackupAndRestore._3cxBackup.ZipFile(String dst, IFile src)
at _3cxNetBackupAndRestore.BackupTasks.BaseFilesTask.BackupFiles()
is there a massive volume of recordings file or not so much?
Ok so it's very small volume
Yes, approx 10 folders.
I was able to copy 2.6gb ubuntu 20 iso file to the usb-hdd.
Ok , is your pbx HDD with enough free space to try the same copy directly on this one?
Yes, plenty of space on the PBX HDD
have run a complete test backup on one of my pbxs with recordings, when it's done i let you know what is my result
Reactions: regomotiv
Ok, thank you very much.
it worked backup file size is nearly 3Go
FTP folder
Same View from PBX console
Ok, thanks for the update.
Even though I get the error message via email, I still get a backup.zip in the PBX console!
could you go to recordings folder here
and try to copy / paste full folder to your external drive
Reactions: JohnS_3CX
Ok, I will do that in a few minutes.
I'm waiting for the backup to finish.
perhaps but if data inside are corrupted then backup may be of no use
I am able to copy the Recordings folder no problem.
To upgrade from v15.5 to v16.x, do all the boxes in the Backup need to be checked?
As you got a copy of recordings out of 3cx process i think you are good to go.
if you are unsure about FTP file , then do a local HDD backup and save it out of 3cx folders, in Documents for example
Full local HDD backup also gives the i/O error.
for upgrade , you need to unisntall V15.5, reboot pc
then install latest V16.6 and restore During install
Reconfigure your backup task while V16 is running
so you are not sure to have a good backup everywhere you tried ?
Can the v15.5 backup just be a backup with only the first 3 boxes checked - "Sys config, license & Chats"?
footandankle.my3fcx.us
