3CX upgrade from Debian 9 to 10 failed
SMC2022
New User
Hey guys,
We tried to upgrade our on-prem 3CX from debian 9 to 10 and it failed.
Attached log file where the update failed, can you please help parsing this information and what steps I could take next?
Thank you
Backup, copy backup off the box, wipe and reinstall from the ISO, restore, and stay current going forward.
Thanks, I'm trying fresh Debian 10 buster ISO install and looking to restore backup.
Will you keep posted on the progress
Hey Guys
I have Debian 10 buster installed and backup restored from Debian 9
But unable to access MC and NGINX shows attached error
Any suggestions?
Thank you.
Hey Guys
Any suggestions?
Thank you.
Are you using a custom SSL? It seems the rights to the files (key and cert) may need changing.
HI @ConceptsWeb
Yes we are using a custom SSL
Can you please guide on how we go about changing permission on files?
You may check the permissions are correct from an SSH terminal to the machine, check Linux guides on how this is to be done. The user and group is phonesystem phoensystem with 0755 rights. But if using your own certificate, the more likely reason is that you will need to ensure that the private key matches the certificate, you will need to check with your certificate provider.
I managed to fix the NGIX & SSL errors and everything is working now on V18.
Thanks everyone.
Reactions: Charles_3CX
