Solved AX83H - KEY TONE RE-ENABLED AFTER PROVISIONNING
Arthur.b
Platinum Partner
Hi everyone,
We're testing the new Wi-Fi Phone from Yealink : AX83H
Currently, we're experiencing a behavior that we don't like and that will bother our potential future customers:
When you disable key tones directly on the phone and then re-provision it from the 3CX admin console, the phone automatically re-enables the key tones.
Do you know if this behavior will be changed?
Reactions: Brailyn
Following...
you can make a custom template and edit this setting to 0:
features.key_tone = 0
Reactions: JohnS_3CX and bitn2
Hi Arthur,
Yes, this was very annoying indeed with these models.
Starting from V20 Update 9, this tone will no longer be re-enabled if you decide to turn it off.
