Call Queue priority
Sven Witlox
I know this has posted before, even got a reply that it was a good idea and it would be implemented but no result yet. Or something simelar like this.
I want to prioritize my agents in a single call queue as I login to the queue. So:
Monday:
Agent 1 -> skill 100% in the queue (direct alerting)
Agent 2 --> skill 50% in the queue (after xx seconds an alert on a call)
Agent 3 --> Skill 50% in the queue (after xx seconds an alert on a call)
Tuesday:
Agent 2 --> skill 100% in the queue (direct alerting)
Tuesday afternoon:
Agent 1 -> Skill 50% in the queue (after xx seconds an alert on a call)
Agent 2 --> Skill 50% in the queue (after xx seconds an alert on a call)
Agent 3 --> skill 100% in the queue (direct alerting)
And so on. My idea is when you logon to a queue you get a notification where you can set your
skill at that point. Or a simple setting (slide bar or something) where you can set the skill at that moment.
I tried "prioritized by three" but when an agent is not logged on this agent does not count anymore and the first three available agent are called. And does not really match my needs at this point.
Now I have 2 queue's setup and different accounts on every workplace to get first or seconds calls, but this is not working properly and I have a lot of issues with the multiple accounts in one 3CX client. The missed calls list is not reliable this way.
Hope there is a solution
Hi Sven,
What you want is true skills based routing, this is not supported as standard with 3CX (which is a shame as I know even some legacy PBX's that support percentage based SBR) unless you have the knowledge to use the Call Flow Designer I would raise it on the appropriate forum group.
Or speak to these guys, they have a smart App written for 3CX that will do SBR for you:
http://www.insperix.com/
Hi Eddv123,
Thanks for your reply, would this be possible with the Call Flow Designer?
The link you provided is to this forum, maybe you have the correct link for the smart App so I can contact them?
Maybe, however I am not sure if there is a mechanism to do the percentage part, I know a lot of these types of partners using the CFD for this exact reason however. Check the link again please.
johnblackwood1
