Solved Config file for inbound SIP trunk from DIDww
vincen
Forum User
Having done config of a new 3CX system on my own hosted system, I had no problem to configure outbound SIP trunks to DIDww without problems by myself but fos inbound trunk it was more difficult as DIDww is not listed as supplier in 3CX.
When you create the inbound SIP trunk in 3CX, use the Provider config file import and use the attached file supplied by DIDww (I created one trunk by incoming DID but on DIDww side I have only one SIP trunk.
Hope it helps ;)
Vincèn
For anyone else reading this, just bear in mind that, regardless of whether a SIP Provider provides a template file or not, if it is not a 3CX Supported Provider it means it has not gone through our interop test process and hence normal functionality cannot be guaranteed.
A list for all 3CX Supported SIP Providers can be found here: https://www.3cx.com/partners/voip-providers/
I'll advise them to join your program to be listed in 3CX and certified compatible ;-)
Great! The more the merrier! ;)
Reactions: vincen
lastshadow
