Configuring Grandstrean GXP-2000 with 3CX
mattbiggs564
I am having trouble configuring My Grandstream GXp-2000 to 3CX, i have tried following the phone set up guide on the 3CX website but i can't get it to work, my 3CX system is being run in the cloud by 3CX, and so i am lost in how to set this up successfully, i am completely new to the system and so i am not massively confident in using it, i know some would recommend upgrading the phone but i am working to a tight budget, and i have been given these devices from a friend and so i want to make these work.
Checking the Activity Log in "Dashboard" and turn on the "Verbose" option in setting for more detail information.
Reactions: JohnS_3CX
You must also ensure the extension Options allow it to register outside the LAN.
Also check if the ip address of the phone or the network where the registration request from is black listed on 3CX server, I have similar issue on a ip phone locally, it keep saying that "unregistered", eventually; I found that the ip address of the phone was black listed due to many bad login.
3K8iMGWviZ
