Grandstream WP820
Gurei123
SMB User
Hi all.
I would like to connect the above wifi phone to 3cxv16 however I do not see it listed on the Add Phone available models. I tried following https://servicemax.com.au/news/grandstream-wp820-and-3cx-setup/
The challenge I am facing with the link above is:
1. I don't have the template that is mentioned
2. I am using 3cx Linux and not sure how to add the template if I get it.
Please assist with detailed steps and template.
Thank you.
Hi @Gurei123
That model is not supported and there are no plans to add support for WiFi based devices.
If you have users that rely on WiFi then we recommend using the 3CX mobile app instead.
Alternatively we would recommend to consider replacing it with a supported DECT phone if you need a portable handset:
DECT Phones​
Lastly, keep in mind that using custom templates means you are also responsible for maintaining and troubleshooting them on your own in case issues arise, since they are not supported by 3CX. If you need to raise a case with 3CX support they will not be able to assist you so it's a good idea to factor this in before recommending unsupported devices to future customers.
Keep away from the WP series from Grandstream. Many issues are still plaguing these models.
Also, the template is outdated as Grandstream doesn't care. So, it doesn't work as expected.
Go with DECT.
Reactions: AWS2P
Finatra.us
