Solved How to receive only external calls?
Martin_Dams
Gold Partner
Intermediate Cert.
Is it possible, using a user-modifiable status, to receive only external calls?
Internal calls would be diverted (or just ended) , and external calls would ring on the extension.
Thank's for your help !
Hi @Vasilis K.,
I already try, but timeout applies for internal call's and for external call's. So when an external call arrive, it ring during 1 second and then the call end
Ah right, silly.
Why not add an exception? You can add a range such as 100-[your last internal extension], and send it to "end call" or VM.
Ok it works, but it's not exactly what I want, because the user must be able to change it easily ^^'.
But I found another way that works!
I add a call group between the external line and the user, and for the status "Away", I check the box "Accept call from call group" in > Forwarding Rules.
This way, the user only accepts calls from his own ring group when he is in "Away" status, and in DND he does not receive any calls.
Thank you for your help !
Great to hear @Martin_Dams, nice workaround. Feel free to open a new thread if you require any further information.
apbGroup
