Incoming normal mobile calls interupting 3CX calls
ThePhoneMan
Does anyone know if there is anyway to make normal mobile calls show as busy when on a call using the app?. Several customers have queried this on both Android and IOS.
TIA
The phones will always prioritise the GSM calls over a data connection.
There is also the possibility that your telco will drop the data connection when a telephone call is coming in. Unfortunately this is something that we cannot control.
@ThePhoneMan Disabling telecom API might help if you want the above behavior, although not recommended
Reactions: OlegR_3CX
ARKC
