IVR and direct extension input
George_Tsi
Hello all,
We recently installed v18 on premises and added some IVR's for inbound. Although we don't mention anywhere "if you know the internal extension, type it now" the feature can be used. Is it possible to disable it for some internal extensions - in case someone types their internal extension during IVR prompt - or disable it in general but keep IVR working?
Thank you
Go to the MGMT console and then Settings > Parameters
filter by IVRDONOTCALL and add the extensions there.
I added the extension there, restarted the services but still if i dial my extension during ivr prompt the extension rings.
Pretty sure that's not used anymore.
Ok try this one.
IVR_DIRECT_DIALING_GRAMMAR
default will be something like:
[0-9]{3}
To block ext 106 for example, do this:
((?!106)[0-9]{3})
To block a range
((?!106|110)[0-9]{3})
Reactions: jed and Evolute IT
Hello all,
Thank you
Use DTMF type IVR. This way you decide what can be entered with full control.
Reactions: jed and George_Tsi
it worked properly when i used DTMF.
Thank you ConceptsWeb and kieferschild for your assistance.
Really appreciate it !
Syedx91
