Solved Update - Maintenance expired - loop
Sven Witlox
We have renewed our license on time to keep the maintenance (and PRO license) active. The only thing is the 3CX was on SP5 and not SP6 and therefore the license on the 3CX could not be activated again because of the
SSL changes on SP6.
Now we have a system which is not working properly because the license is expired and I cannot
update to SP6 because the maintenance is expired....it's an infinite loop.
Please help.
Backup, uninstall, reinstall, restore. Process is covered in the certification you have...
Oh if you running under Debian you can probably do an in-place upgrade via apt.
Reactions: Sven Witlox
running Debian, i'm going to have a look at that.
thanks man, upgrade via Debian did the trick! Now running on SP6 and I have
an active license again.
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
Rhameez
