3CX U.S. customers can now combine the services of one of the country's leading SIP trunk providers, Nexmo, and 3CX V15.5. After completing successful testing, Nexmo SIP trunk is now available for selection from within the 3CX management console.
Since 2010 Nexmo has offered its SIP trunking services to businesses in the U.S. working on a national and international level, helping them to grow with a reliable, innovative and affordable solution that works with existing infrastructures. With Nexmo's easy to use platform, ready to work with 3CX, you can instantly provision your trunks and have your PBX up and running in minutes. 3CX customers can now make use of Nexmo's cost-effective SIP solution in just a few simple steps.
By following our step-by-step guide and using our pre-configured template, you can quickly and easily configure your 3CX PBX with Nexmo's SIP trunk. Head on over to our configuration guide and login to the management console to get started. Please note that to use Nexmo's SIP trunk you must be running 3CX V15.5 SP2. It is recommended that you always run the latest version of 3CX in order to ensure ongoing compatibility.
