Group Management
Keith Gauci
Forum User
Hi all,
Hope all is well!
I need to dedicate a range of extensions. Lets say 100 till 200 to a department.
Now I want that range can only see and call those extensions and not all the others. Ex: I want that 101 can see from 100 to 200 and not 010.
I have all the extensions in their respective department group.
In the group rights > global rights. The publish group information to all extensions is not ticked. But still all groups can see all extensions.
Am I missing something?
Regards,
Keith
The user is probably in multiple group, thus why you see all of them. Also, even if the user doesn't SEE the other extensions on the Webclient/apps, they can still call them if they have the ext number. There's no restrictions there and no, there's no way to put some.
Hi Frederick,
I will set up the publish group info on every group then.
Thank you for your help! :)
tohoken1
