SMS no longer available on 3CX hosted instance after upgrade
doncol
We have a situation where a previously working SMS integration was working fine until the 3CX hosted install was upgraded overnight. Now, there is nowhere to add/edit any SMS configuration. The SIP Trunk provider and account is the same as it has always been, and has never been an issue. This has worked through v16 and into v18 until now. Is there something we are missing here with the upgrade to v18.0 Update 6 (Build 908)?
Unfortunately not SnakeRiverWeb. This system has been using an SMS gateway service through Telnyx, not an SMS enabled DID. Originally it was setup under 'Messaging' in v16.x, which no longer exists. Added to that, the SIP Trunk (a 3CX preferred provider here in Australia) does not have the SMS option available for the trunk.
Looks like you have 2 choices, move to self hosted or change SMS providers as Telnyx is no longer supported.
You probably missed this at the time: https://www.3cx.com/blog/news/messaging-updates-u6/
Telnyx appears in the US providers under 3rd Party.
If you are in Australia I think also have Twilio as an option from the list of international providers.
sherry reynolds
