Release of 3CX Android app beta with full Android 15 support, delivering smoother performance.
Hot on the heels of the release of Android 15 just a few days ago, the latest 3CX Android app Beta now fully supports the new OS. With improvements in performance and stability, you’ll stay connected without interruptions. Here’s a closer look at what’s new in this version.
More Reliable Connections & Improved Security
Internal libraries have been updated to improve security and ensure reliable connections. These updates reduce the chances of call drops or connection issues even during high call volumes.
Clearer Calls with Better Audio Focus
Android 15 improves audio focus, and the 3CX app takes full advantage. When you’re on a call, any audio from other apps will pause or mute, ensuring a conversation that’s distraction-free. Once your call ends, the audio resumes, enhancing your experience when switching between apps.
Additional Fixes and Updates
- Improved handling of Android’s "Do Not Disturb" feature, muting ringtones but allowing vibration alerts.
- Improved chat transfer notifications, ensuring recipients are clearly informed of the sender when a chat is transferred.
Reminder: App Permissions for Stability
Ensure all necessary permissions, including unrestricted background access, are enabled for optimal performance. For help, check out our Android PUSH troubleshooting guide.
Try Out the Beta
Join our Beta testing program and try out the latest Android Beta update! Download the app from the Google Play Store.
For instructions on how to install and provision the 3CX Android app, see our configuration guide.
